Geologic Mapping with QField¶
By Rohanna Gibson, Structural Geologist, Terrane Geoscience
Päämäärä¶
Projektin esivalmistelut¶
Prior to starting in QField, a geologic mapping GeoPackage was designed to collect vector data including point station, structure, photo, and sample layers as well as line and polygon layers for contacts, faults, alteration, and geology. Attribute fields are customized for ease of data entry and data quality assurance using value maps, defaults (value or expression), and constraints within the Attributes Form. For example, the structural layer includes:
Koordinaatit
Fields with default value x and y coordinates from GPS data.
Structure type
Value map (drop down list) with structural features (e.g., bedding, cleavage, lineation), set with a "not null" constraint.
Azimuth and dip
Integers with range set from 0-360 and 0-90, respectively.
Päivämäärä
In addition to field data, base maps and historic data are compiled into GeoPackage for reference. Base maps include vector topographic data and raster orthophotos. Raster geophysical data and vector geochemical data are included if available, as well as historic geologic mapping. Map themes are designed to quickly toggle between geologic mapping, geophysics, and geochemistry views.
Tietojen kerääminen¶
Tulokset¶
