Tips and Tricks for your QGIS project
This page will give you an overview of all the tips and tricks you can apply to your project and general workflow to minimize synchronization errors, work efficiently and save storage.
Project Configuration Best Practices
To ensure a smooth synchronization process between QGIS, QField and QFieldCloud, follow these recommendations.
1. Centralized Data Storage - Add all data in the same folder as your .qgs project file
Before uploading your project, ensure all relevant data sources (GeoPackages, rasters, etc.) are located in the same directory as your project file (.qgs/.qgz) or in a subdirectory (e.g., ./data, ./assets). If files are spread across different drives or folders on your computer, QFieldSync and QFieldCloud may fail to package them correctly for the mobile device.
2. Managing Unique IDs - Add a unique ID to your layers
When multiple users collect data offline simultaneously, standard auto-incrementing IDs (1, 2, 3...) will result in conflict errors when applying the deltas changes data on QFieldCloud.
  • For Relations: Create a specific text field (e.g., survey_uuid) and use uuid() or uuid('WithoutBraces') as the default value. Use this field for all foreign keys and for primary key if the layer is from PostgreSQL/PostGIS.
  • For the fid (Feature ID): If you are working with GeoPackages, you can reduce conflicts on the internal fid integer column by setting the "Default Value" to the expression epoch(now()). This generates a unique integer based on the current timestamp.
Tip
To set this up, go to Layer Properties > Attributes Form, select the fid field, and set the Default Value to:
epoch(now())
Ensure the "Apply default value on update" box is unchecked so the ID remains constant after creation.
3. Relative Paths - Ensure that all attachment paths are relative
Absolute paths (e.g., C:\Users\{username}\Downloads\photo_001.jpg) will break when the project is transferred to a mobile device (Android/iOS), as the file system structure is different.
  1. Navigate to Project > Properties... > General.
  2. Set Save paths to Relative.
4. Stable Layer References in Expressions - Use the Layer Name in expressions, not the Layer ID
When writing expressions (for example, inside aggregate() or relation_aggregate()) functions, QGIS allows you to reference layers by their internal ID (e.g., places_2348274...) or their Name (e.g., Places). Always use the Layer Name (e.g., Places).
Why? The internal Layer ID changes if you remove and re-add a layer or internally in QFieldCloud when a packaging job is triggered could change, which breaks your expressions. The Layer Name remains stable as long as you do not rename it in the layer tree.
5. Preferred File Formats - Convert your layers to GeoPackage
QField and QFieldCloud are optimized for the GeoPackage (.gpkg) format. While QField and QFieldCloud support others formats like Shapefiles (.shp), GeoJSON, and KML, etc., is strongly recommend converting these layers to GeoPackage before starting your project.
How to Convert to GeoPackage?
  1. In QGIS, right-click your layer in the layer tree.
  2. Select Export > Save Features As...
  3. Set Format to GeoPackage
  4. In File name, click ... and navigate to your project folder. Give the new database a name (e.g., notes_points.gpkg`)
  5. In Layer name, give your layer a simple name (e.g., notes_points)
  6. Click OK
  7. The new layer will load into your project. You can now remove the old layer
6. Modular File Structure - Store one layer per GeoPackage
QFieldCloud manages versions and backups at the file level. Every time changes are synchronized, a backup of the modified file is created.
  • The Risk: If you store multiple layers in a single GeoPackage (e.g., survey_data.gpkg containing Trees, Roads, and Buildings), restoring a backup to fix an error in the Trees layer will also roll back valid work done on Roads and Buildings during that same period.
  • The Solution: Save each layer in its own separate GeoPackage (e.g., trees.gpkg, roads.gpkg). This allows you to restore a previous version of one specific layer without losing data in others.
Common Configuration Errors
If you are experiencing synchronization issues, check for these common configuration errors:
Issue Cause Solution
Missing Images Paths are set to "Absolute" Go to Project Properties and set paths to "Relative".
Sync Failures Data is outside the project folder Move all .gpkg and raster files into the same folder as the project file (.qgz/.qgs).
Expression Errors Layer ID used in expression Update expressions to use 'Layer Name' instead of 'Layer_ID_123'.
Duplicate Keys Using default 1, 2, 3 IDs Implement uuid() or epoch(now()) for unique identification.
Download attachments only on demand
In the QFieldCloud settings you can set your attachments to be only downloaded on demand. This is particularly useful when you work with an abundance of photos and do not need all your attachments at once.
To enable this feature:
  1. From the QFieldCloud landing page, select your project.
  2. Direct to Settings.
  3. Enable the "On demand attachment files download" option.
This feature can be activated during project creation or enabled at any time for existing projects. You need to be online to download the attachments on demand. If you work offline, it will only show a blank screen.
Automatic push to QFieldCloud
When being in the field and doing lots of changes that include a lot of attachments, it is recommended to synchronize to the cloud as often as possible to avoid data loss. With this functionality, you can enforce automatic pushing of pending changes to QField devices in the field, as well as specify the interval in between automated pushes. The functionality is activated through a project setting, allowing remote activation.
  1. Access Project Settings: Direct to Project > Properties... > QField > QFieldCloud Packaging
  2. Enable Auto-Push: Toggle the "Automatically push pending changes on the following interval" option and establish your preferred interval.
Auto push QFieldSync
  1. Open the Side Dashboard and tap the cloud icon
  2. Enable the automatic push setting (this is set to a default value of 30 minutes if project is not configured)
Auto push QField
Auto push QField
Benefits:
  • Real-Time Updates: Ensures prompt Synchronisation of field data with the QFieldCloud project.
  • Streamlined Workflow: Minimizes manual intervention and ensures surveyors do not need to worry about Synchronisation, helping them focus on data quality.
Considerations:
  • Network Stability: Ensure stable internet connectivity for auto-push functionality.
  • Battery Optimization: Implement strategies to mitigate battery consumption on QField devices during prolonged fieldwork.
Restriction of Project Files
If you work in field operations which involves a lot of users, it may be useful to restrict the QGIS project file to prevent all users with editor rights to download the project and make changes to the configuration. To prevent any modification to the core QGIS project file, the project administrator can restrict the access to these files. This can be achieved under the settings section in QFieldCloud.
Desktop
  1. From the QFieldCloud homepage direct to Settings
  2. Enable the Restrict project files button
Restricted Files
When enabled, the following files can only be modified or uploaded by a user with an "admin" or "manager" role for the project:
  • The primary QGIS project file (e.g., my_project.qgz).
  • The attachments zip archive associated with the project (e.g., my_project_attachments.zip).
  • QGIS auxiliary data files that store information like label positions (e.g., my_project.qgd).
  • QField style files (.qml) that share the same name as the project file.
Saving storage
Deleting old file versions
You can reduce the number of versions you want to keep of any given file to reduce the amount of storage needed by accounts. One can manually delete file versions from the project's File section. Each file and version can be linked to a specific QFieldCloud user who uploaded it.
  1. Go to the "Files" section of your project.
  2. Locate the file for which you want to delete versions.
  3. Click on the 3-dotted menu (⋮) on the right side of the file name.
  4. You will see a list of versions for that specific file.
  5. Identify the version you want to delete and click on the red trash bin icon next to it.
    Deleting project files
  6. Confirm the deletion when prompted, if you want to delete all versions before a specific version, you can do it activating the option "Also delete n version(s) older than the selected version.".
  7. After deleting a pop up message will appear with the success and the list of versions will show just the versions that was not selected for deletion.
Set maximum pixel size of attachment
If you want to further save space and you are working with attachments, you can reduce the pixel size. This will lead to lower image quality but take less storage on QFieldCloud. You can direct to the How-To of the Attachment Widget to see the step-by-step instructions.
Automating file deletion with QFieldCloud SDK
If you accumulate many attachments (such as high-resolution photos) during fieldwork and want to free up space automatically without manually deleting them from the web interface, you can utilize the QFieldCloud SDK.
By setting up a script or a cron job using the QFieldCloud SDK, you can periodically purge specific file types (e.g., .jpg or .mp4) to keep your storage usage low.
For full details and code snippets, see the QFieldCloud SDK Documentation.
To routinely free up storage quota on QFieldCloud, you can delete unnecessary files, such as heavy .jpg attachments using glob patterns.
client.delete_files(
    project_id="123e4567-e89b-12d3-a456-426614174000",
    glob_patterns=["*.csv", "*.jpg"],
    throw_on_error=True
qfieldcloud-cli delete-files '123e4567-e89b-12d3-a456-426614174000' '*.jpg'
qfieldcloud-cli delete-files "123e4567-e89b-12d3-a456-426614174000" "*.jpg"
