Stile della mappa¶
Espressione di Visualizzazione¶
Preparazione da Desktop
In QField, objects are identified with a name. The expression to generate this name can be defined by opening the attribute table in QGIS and switching to the form view. Choose the appropriate field or an expression in the list there. Starting from QGIS 3, this can be done directly from the Vector Layer Properties > Display page.
L'espressione di visualizzazione viene utilizzata anche per cercare nei layer.
Layer di sola lettura, non identificabili e ricercabili¶
Some layers in a project are just there for pure visual purpose. Such layers should not show up when a user taps somewhere to identify objects.
Some other layers serve as source of information and shouldn't be modified by the user. It is possible to protect layers from editing attributes or adding and deleting features.
È anche possibile configurare quali layer sono ricercabili.
To configure identify, read-only and searchable behavior, go to the Project > Properties > Data Sources page and activate the checkboxes to match your desired behavior.
Utilizzo di caratteri aggiuntivi¶
QField enables you to use all the custom fonts you might want and need. There are two different possibilities to register additional fonts:
- By adding fonts (.ttf or .otf) on the device in the folder
<drive>:/Android/data/ch.opengis.qfield/files/QField/fonts. Those will be made accessible to all projects and individual datasets. - By adding fonts (
.ttfor.otf) in afontssubfolder of the folder containing a given project file (.qgsor.qgz). Those fonts will only be accessible when viewing that project.
Simboli SVG personalizzati¶
It is possible to embed SVG symbols directly within a QGIS project.
- Scegli il layer che supporterà la simbologia SVG e apri la sua finestra di dialogo delle proprietà.
- Apri la sezione Simbologia in Properties > Symbology
- Nel Pannello dei livelli simbolo scegli Marcatore semplice.
- Modifica il tipo di layer Simbolo in Tipo di layer Simbolo > Marcatore SVG.
- Scorri il pannello inferiore.
- Clicca sul lato destro del pulsante di selezione del file per aprire il
menu a tendina.
- Seleziona Incorpora file e scegli il file SVG nel dialogo di selezione dei file.
- Applica le modifiche e clicca su OK.
