Kartan tyylit¶
Näyttölauseke¶
Työaseman valmistelu
In QField, objects are identified with a name, which can be customized using expressions.
- Open the attribute table in QGIS and switch to the form view.
- Direct to Vector Layer Properties > Display > Attribute.
Näyttölauseketta käytetään myös hakemiseen tasoilta.
Ainoastaan luettavat, ei-tunnistettavat ja haettavat tasot¶
Some layers in a project are just there for pure visual purpose. Such layers should not show up when a user taps somewhere to identify objects.
Some other layers serve as source of information and shouldn't be modified by the user. It is possible to protect layers from editing attributes or adding and deleting features.
On myös mahdollista asettaa millä tasoilla voi hakea.
- Direct to Project > Properties... > Data Sources and activate the checkboxes to match your desired behaviour.
Lisäfonttien käyttö¶
QField enables you to use all the custom fonts you might want and need. There are two different possibilities to register additional fonts:
Addition of fonts through the local directory
- Copy your font file (.ttf or .otf) in the directory [App Directory]/QField/fonts. Those will be made accessible to all projects and individual datasets.
Addition of fonts in subfolder of QGIS file
- Create a subfolder called fonts inside the same folder where your given project file (
.qgs
or.qgz
). is stored. Those fonts will only be accessible when viewing that project.
Mukautetut SVG-symbolit¶
It is possible to embed SVG symbols directly within a QGIS project.
- Valitse taso joka tukee SVG symboleja ja avaa sen Ominaisuudet... ikkuna.
- Open the section Symbology in Properties > Symbology
- Valitse Symbolitason-paneelista Yksinkertainen merkki.
- Change the symbol layer type in Symbol layer type > SVG marker.
- Scroll down to the bottom panel.
- Klikkaa tiedostovalinnan oikealla puolen avataksesi alasveto valikon.
- Select Embed File and choose the SVG file in the file selection dialog.
- Apply the changes and click OK.
