输出为PDF
可以在QGIS中配置工程的打印布局,将地图导出为PDF文档。
用法
QField界面
Printing to PDF is available through QField's main menu bar in the side "Dashboard".
If the opened project has a single print layout defined, selecting the "Print to PDF" menu will immediately launch an export of the layout to PDF. If more than one print layout is present, a submenu will appear listing all the available layouts to choose from.
导出打印布局后,QField将允许用户打开和查看所创建的PDF文档。
"要素-驱使" 地图集输出
You can also print an atlas-driven layout by selecting features from vector layers acting as coverage layers. To do so, identify features on the map by tapping on the canvas and hold-press on a feature in the list to toggle the (multi-)feature selection mode. Once the desired features are selected, click on the 3-dotted menu (⋮) button and select Print Atlas Feature(s) to PDF.
It is possible to print a single atlas feature through the feature form by clicking on the 3-dotted menu (⋮) button and selecting the Print Atlas Feature to PDF.
