Estilos do mapa¶
Exibir Expressão¶
Preparação no Desktop
In QField, objects are identified with a name, which can be customized using expressions.
- Open the attribute table in QGIS and switch to the form view.
- Direct to Vector Layer Properties > Display > Attribute.
A expressão de visualização também é usada para pesquisa nas camadas.
Camadas apenas de leitura, não editáveis e pesquisáveis¶
Some layers in a project are just there for pure visual purpose. Such layers should not show up when a user taps somewhere to identify objects.
Some other layers serve as source of information and shouldn't be modified by the user. It is possible to protect layers from editing attributes or adding and deleting features.
Também é possível configurar que camadas são de pesquisa.
- Direct to Project > Properties... > Data Sources and activate the checkboxes to match your desired behaviour.
Usar tipos de fontes adicionais¶
QField enables you to use all the custom fonts you might want and need. There are two different possibilities to register additional fonts:
Addition of fonts through the local directory
- Copy your font file (.ttf or .otf) in the directory [App Directory]/QField/fonts. Those will be made accessible to all projects and individual datasets.
Addition of fonts in subfolder of QGIS file
- Create a subfolder called fonts inside the same folder where your given project file (
.qgsor.qgz). is stored. Those fonts will only be accessible when viewing that project.
Símbolos SVG personalizados¶
It is possible to embed SVG symbols directly within a QGIS project.
- Escolha a camada que suportará a simbologia SVG e abra sua caixa de diálogo de propriedades.
- Open the section Symbology in Properties > Symbology
- No Painel de Símbolo da Camada escolhe Marcador simples.
- Change the symbol layer type in Symbol layer type > SVG marker.
- Scroll down to the bottom panel.
- Clique no lado direito do botão de seleção do ficheiro para abrir o menu suspenso.
- Select Embed File and choose the SVG file in the file selection dialog.
- Apply the changes and click OK.
