Sari la conținut
Standalone datasets
QField is able to directly open vector data and raster datasets without the need for a QGIS project.
Supported standalone dataset formats
The supported vector formats are:
  • GeoPackage datasets (.gpkg);
  • GeoJSON (.geojson, .json);
  • KML (.kml, .kmz);
  • Shapefile (.shp);
  • GPS Exchange (.gpx);
  • Geography Markup Language (.gml);
  • MapInfo (.mif);
  • SpatiaLite (.db, .sqlite); and
  • FlatGeoBuf (.fgb)
The supported raster formats are:
  • GeoTIFF (.tif, .tiff);
  • Geospatial PDF (.pdf);
  • JPEG2000 (.jp2);
  • JPEG (.jpg, .jpeg);
  • PNG (.png); and
  • WebP (.webp)
  • VRT (Virtual Raster) (.vrt)
Supported point cloud formats:
  • LAS/LAZ (.las, .laz)
  • COPC (Cloud Optimized Point Cloud)
QField can handle several standalone datasets compressed into one ZIP archive; in this scenario, each dataset will be added as individual layers in QField.
Opening an vector or raster dataset
Muncă de teren
Please read the storage access documentation to learn more on how standalone datasets are opened on your specific device.
Using a project as "base map" for standalone datasets
Muncă de teren
By default, the datasets will be overlaying an OpenStreetMap XYZ layer. It is however possible to customize that by selecting a project stored onto the device QField is running that will act as a base map.
To use an existing project as base map, do a long press on a project in the recent projects list and check Base Map Project.
