Sari la conținut
Map themes
The beautiful thing about GIS is that maps are dynamic. Layers can individually be shown and hidden and information can be presented more or less prominently based on the task at hand.
This is what Map themes are for.
Crearea unei Teme de Hartă
Pregătire desktop
Crearea unei Teme de Hartă în QGIS reprezintă o activitate facilă.
Map Theme Configuration
  1. Style the map and layers to your requirements.
  2. Save it as a named Map Theme.
  3. Load the project on your device and change the active Map Theme.
Schimbare Temă pentru Harta activă
Muncă de teren
If you defined map themes for your project in QGIS, you can switch between them from the side "Dashboard". Use the Map themes combobox to chose the active theme.
