Temas de mapa¶
The beautiful thing about GIS is that maps are dynamic. Layers can individually be shown and hidden and information can be presented more or less prominently based on the task at hand.
Para que servem os Temas de Mapa.
Criar um Tema de Mapa¶
Preparação no Desktop
Criar um Tema de Mapa no QGIS é uma tarefa muito simples.
- Style the map and layers to your requirements.
- Save it as a named Map Theme.
- Load the project on your device and change the active Map Theme.
Alterar o Tema do Mapa activo¶
Trabalho de campo
If you defined map themes for your project in QGIS, you can switch between them from the side "Dashboard". Use the Map themes combobox to chose the active theme.
