Relation Reference Widget
In a building there are several apartments with different owners. We can create a relation between the building and the apartments and between the apartments and the owners.
Relation configuration
Before adding, editing or viewing the related features you have to set up a relation between the two layers. Here it is important that you add an id (primary key) field to the parent layer (Reference Layer) that can be used as a foreign key in the child layer (Referencing layer). These fields are used for creating the link between the two layers. Therefore, they must be unique. Note: It is good practice to use uuid's as "unique ids" given they are 36 characters long and also contain non-numerical characters making them much safer to use over ordinary numerical ids.
Creating the relation
  1. Direct to Project > Properties > Relations
  2. Press the green plus to add a new relation
  3. Set your Reference and your Referenced Layer in addition to the corresponding fields that will be used for the linking. For more details please refer to the official QGIS documentation
  1. Direct to the Layer Properties > Attribute Form
  2. Find your reference field, set the widget type to UIID generator and set a default value to *uuid('WithoutBraces')
  3. Find your relation under the "Relations Section" and add it to the form layout
  4. Set the Cardinality to "Many to one relation"
  5. Under the widget you can define whether children can be:
    • linked
    • unlinked
    • edited
    • added
    • duplicated
    • deleted
    • zoomed into
  6. (Optional) If you want to filter your children further, you can use additional "expressions".
  7. Once finished click "ok"
  2. Configure your attribute form with the wanted fields.
  3. (Optional): Under Display you can set the appearance of how the children will be displayed
Maximum number of visible children
  • Default Number of visible children: 4 children
  • Unlimited: Empty
  1. Direct to Vector Layer Properties... > QField.
  2. Under "Relationship Settings" set the "Maximum number of items visible".
Maximum items visible for relation
QField Visible items
Many-To-Many relations
Ordered Relation
  1. Install the Plugin Ordered Relation Editor plugin from the official repository or through the "Plugin Manager" in QGIS.
  2. Open the Vector Layer Properties... > Attributes Form and set the layout editor to Drag and Drop Designer.
  3. Click on the relationship of your available widgets.
  4. Direct to Properties > Attribute Form and find your relation under the relationship section.
  5. On the right under "Widget Display" scroll down to the "Widget Type option and select Ordered Relation Editor.
  6. Configure the widget using the following settings:
    • Ordering Field: Specify the field in the child layer that will be used to determine the order of the features.
    • Description: Define an expression to be displayed for each child feature in the list.
    • Image Path (Optional): Provide a path to an image or icon to visually enhance the list. This is an expression that resolves dynamically.
Widget configuration in QGIS
Search in value relation and relation reference widget
