Hyppää sisältöön
Ajallinen suodatus
When QField consumes projects containing one or more layers with active temporal settings, a temporal filtering indicator located within the "Side Dashboard" appears next to the map theme combo box. A green clock icon indicates temporal properties are filtering features drawn on the map canvas is active, while a gray clock icon indicates the filtering is turned off.
Ajallisen suodatuksen säätäminen
When clicking on the side "Dashboard's" temporal filtering indicator, a temporal properties panel pops up. From there, you can enable the temporal filter and set the temporal range's beginning and end time.
QFieldin ajallinen suodatus toimii täsmälleen kuten QGIS:n kiinteän alueen ajallinen navigointitila.
