Karttateemat¶
The beautiful thing about GIS is that maps are dynamic. Layers can individually be shown and hidden and information can be presented more or less prominently based on the task at hand.
Tätä varten Karttateemat on tarkoitettu.
Karttateeman luonti¶
Työaseman valmistelu
Kartta teeman luonti on QGISissa yksinkertainen toimenpide.
- Style the map and layers to your requirements.
- Save it as a named Map Theme.
- Load the project on your device and change the active Map Theme.
Vaihda aktiivisen kartan teemaa.¶
If you defined map themes for your project in QGIS, you can switch between them from the side "Dashboard". Use the Map themes combobox to chose the active theme.
