Sari la conținut
Interact with the map
Here are some of the possible interactions with the map in QField.
Legenda hărții
Muncă de teren
Open the side "Dashboard" and expand the layers list to display the legend of the map.
On double-tap or long-press on a layer, you get offered the following possibilities.
  • Expand legend item to show/hide the layer's sub-items.
  • Show on map to control visibility.
  • Show labels to control the visibility of the labels.
  • Opacity Slider to control the transparency of the layer.
  • Zoom to layer to have all the layer items on the map.
  • Reload icon to get the current data of a layer with remote sources.
  • Show feature list to show all the layer's features in the identification list.
  • Setup tracking to set up tracking mode of layer.
Sort layer features
Pregătire desktop
If you'd like to configure the order of features in "Show feature list" in QField, you have the following options to pre-configure this on QGIS:
  • Simply right-click on any part of a column header and select the "Sort" option from the menu. This allows you to enter complex sorting expressions for your features as required.
  • When being in the form view, you can access the sorting functionality by clicking on the expression button located at the top of the features list and select the "Sort" option.
Identificare entități
Muncă de teren
Tap on a feature on the map to identify it. If several features are located where you tapped (either because there are multiple features really close one to another, or because several layers are overlapping), they will all be listed in the menu that opens on the right of the screen.
Tap on one of the listed features to access its attributes.
  1. Tap the arrows to scroll through all the identified features.
  2. Tap the centre button to centre the map on the selected feature.
  3. Tap the edit button to edit the attributes of the selected feature.
  4. Scroll through the sub-menus to access all the attributes.
Select identified features
With long-press, you can toggle the feature selection.
When features are selected, you can perform the actions in the 3-dotted menu (⋮) on the top right.
Straturi exceptate de la identificare
Often it is not required to be able to query every layer. Some layers are only present as basemap, and their attributes are not of interest.
You can manage this layer list in QGIS desktop in Project > Properties... > Data sources > Identify Layers and uncheck the base layers.
3D map view interactions
Muncă de teren
QField supports viewing and interacting with your project data in a 3D map view. By utilizing elevation data (either an automatic online DEM or a custom DEM configured in your QGIS project), your map layers are draped as textures over the 3D surface. You can interactively navigate your map in 3D and seamlessly synchronize extents with the 2D canvas.
Learn more about configuring and using the 3D Map View.
