Hyppää sisältöön
Siirrettävä projekti
To manually synchronize your QGIS project, you will need a portable version of your QGIS project file (.qgs, .qgz). Portable means that all paths are relative and datasets are reachable from the device.
Määritä siirrettävä projekti
Työaseman valmistelu
Check that Project > Properties > General > Save paths is set to Relative and that all required data files are in the same folder like the QGIS project file or in a subfolder.
