Working with PostgreSQL¶
PostgreSQL in QField¶
Working with databases can be much easier when working in a multi-user environment or when working in a variety of projects that require more complex data structures. With QField you can easily work within a database but there are a few steps that need to be taken before the smoothless fieldwork can begin. This page goes through the different options and gives step-by-step instructions on how this can be achieved.
Connection to PostgreSQL in QGIS¶
In QGIS there are two options in which you can connect to your database.
- Direct Connection: When connecting to a PostgreSQL database, you can store all information including the credentials inside the QGIS Project directly.
- Using a PG Service File: Using a service file that holds the connection parameters to all your databases as an individual service name. Independently on working with our without QFieldCloud, we highly recommend to make use of this option due to data safety.
Direct Connection using Simple Authentication¶
You can create a PostgreSQL connection directly inside QGIS. NOTE: We do not recommend this option due to data safety reasons. It is not safe to store your database credentials in the QGIS Project File.
- In your Browser right-click on the PostgreSQL Elephant > New Connection
- In the window give your connection a name and add the service information in the dialogue (host, dbname, port, SSL mode)
- In the "Authentication section", add a new Authentication if you have not yet connected to your database and saved the credentials.
- Test the connection and when successful click ok.
- Create a new project on QFieldCloud, choosing the second option to keep the connection to your database.
- Configure the layers and the project according to your needs and synchronize with QFieldCloud.
If you have added the access credentials in the "Authentication" section as described above, QField will be able to directly start editing and adding new features.
Connection via PG service¶
It is possible to connect to postgreSQL via a service using a service file.
A service is stored inside the pg_service.conf file where all the required information to access your database is stored.
Instead of storing the hostname, port, database name and more into the QGIS Project file, these can be stored separately.
Using services is very useful, when you work with multiple database connections during your everyday work to quickly change and connect to the different instances.
Read more about PostgreSQL services in the QGIS documentation.
There exists a useful plugin, which supports in the easy creation and configuration of the service file - the PG Service Parser Plugin. We recommend using this plugin and will show you below how to use it.
Desktop Preparation
- Direct to Plugins > Manage and Install Plugins
- Search for "PG service parser" (icon of the PostgresSQL Elephant) and install it.
- Once installed, in the QGIS toolbar, the same icon should appear.
- Upon clicking on the icon a new window will appear.
If you never set-up a service file before, the plugin will automatically create a new file in a proper default directory, which ensures QGIS will be able to read it.
Create config file -
Click on "Create file at default location" and leave the default name.
Now you can configure the database information which will be stored as a PG service.
Create service
- Click on the green plus within the PG service parser plugin
- Add the different setting options by clicking on each required option and click "OK"
- Edit the database information by double-clicking on the different sections.
- Once you are done, click on the Update service button so save the configuration.
- Keep the window open, as we will use it in the next section.
Connection to PostGIS via service
- Within the dialog of the PG service parser plugin, go to the QGIS Connections tab.
- If needed, select the service you'll use to connect to PostGIS.
- Click on the green plus to add a new connection.
- Click on "OK" to accept a default connection name or enter your preferred name for the connection, which could contain spaces.
- Double click on the new entry displayed and click on the Test Connection button. If successful, click OK. Note: You can edit connection details to "also list tables with no geometry" or "Use estimated table metadata" to customize your connection.
- Once you are done, you can close the plugin dialog.
The new QGIS Connection will appear in your browser, listed under the PostgreSQL item.
Conexión con PostGIS en QField¶
Si se ha conectado a PostGIS utilizando el archivo de servicio PG, también es necesario agregar el archivo de servicio, ya sea directamente en su dispositivo móvil o dentro de QFieldCloud como un "Secreto".
Configuración en el dispositivo móvil¶
Si copias sus proyectos a su dispositivo mediante cable, también tendrá que copiar el archivo de servicio al directorio correcto en tu dispositivo.
Generalmente, el directorio QField para Android se encuentra en /Android/data/ch.opengis.qfield/files/QField.
Nota
1. Debido a las restricciones de Android, solo podrá acceder al directorio cuando esté conectado al ordenador mediante cable. La única otra opción posible es obtener acceso root en su dispositivo (no recomendado). 2. A diferencia de los sistemas *NIX, donde el archivo se llama .pg_service.conf, en Android se llama pg_service.conf sin punto inicial (.).
Configuración en QFieldCloud¶
QFieldCloud también admite la configuración de pg_service.conf. Debe configurar sus capas de PostgreSQL con la acción en la nube "Edición sin conexión" y guardar la configuración del servicio en la página de secretos del proyecto QFieldCloud.
Read more how to configure PostgreSQL service in the QFieldCloud documentation.
Creación de un archivo pg_service.conf para la conexión PostgreSQL en QGIS y Secrets¶
Before beginning, ensure that your PostgreSQL database allows connections from QFieldCloud. Refer to Technical specs for instructions.
Configurar el archivo pg_service.conf.¶
Primero necesitamos crear un archivo de configuración. Hay muchas opciones para organizar esto. Más información en la documentación de PostgreSQL o siga la descripción a continuación.
Crear un archivo de configuración:
En Windows: Cree un archivo llamado
pg_service.confy guárdelo en una ubicación conveniente. -
En Linux/MacOS/Unix: Cree un archivo llamado
.pg_service.confen su carpeta de inicio (~). -
Definir parámetros de conexión:
Dentro del archivo, especifique los parámetros de conexión para su base de datos PostgreSQL utilizando el siguiente formato:
[SERVICE_NAME]
host=your_host_or_ip
port=your_port
dbname=your_database_name
user=your_username
password=your_password
Sustituya los marcadores de posición (tu_host_o_ip, tu_puerto, tu_nombre_basedatos, tu_nombreusuario, tu_contraseña) por los detalles reales de la conexión y guarde el archivo.
Pasos adicionales de configuración para Windows¶
Establecer variable de entorno: Para asegurarse de que QGIS reconoce
pg_service.conf, cree una variable de entorno que apunte a su ubicación:- Navigate to This PC or My Computer > Properties > Advanced System Settings > Environment Variables.
- Añadir una variable nueva:
- Nombre de la variable:
PGSERVICEFILE - Valor variable:
C:\Users\<YourUsername>\AppData\Roaming\postgresql\pg_service.conf(or yourpg_service.conffile path).
Set Environment Variable in QGIS
- Direct to Settings > Options > System
- Under the Systems tab, find the Environment Section, enable the Use custom variables and add the file location to your pg service file as shown in the image below.
Refer to QGIS System Settings for details.
Using Client Certificates¶
It is possible for you to use client certificates to verify the identity while connecting to a PostgreSQL server by defining additional parameters in your pg_service.conf, namely sslcert, sslkey, and sslrootcet.
[SERVICE_NAME]
port=your_port
user=your_username
sslcert=client.crt
sslkey=client.key
sslrootcert=server.crt
These parameters must point to valid certificate and key files and placed directly alongside your pg_service.conf file within the QField data folder. For more information on this identification method, refer to the PostgreSQL documentation.
