Positioning (GNSS)
GNSS devices are also capable of measuring the altitude next to the current 2D position on the earth surface.
Configuration
Vertex log
Then you should assign the role digitizing logger on a point layer.
Go to QFieldSync > Project Properties
Accuracy requirement
If the Enable accuracy requirement setting is activated, you will not be able to collect new measurements with the cursor snapped to the position with an accuracy value which is bad (red).
Antenna height compensation
Vertical grid shift files have to be made available to QField by putting them into the QField app folder <drive>:/Android/data/ch.opengis.qfield/files/QField/proj.
Since QField 2 the proj files needs to be stored in the app directory <drive>:/Android/data/ch.opengis.qfield/files/QField/proj instead of the devices main directory <drive>:/QField/proj.
Once the grid shift file is placed there, it is available in QField in the Positioning settings under Vertical grid shift in use.
Additional variables
  • @position_source_name - The name of the device that gave location information as reported by the sensor. To differenciate between internal and external sensor. If the position is manually set, and the position is not snapped to the cursor, the source name is "manual". In case the cursor is not snapped to the position, all other variables will be null, if you need this, use the gnss_ variables instead.
  • @position_quality_description - A human readable and translated string for the quality as reported by the sensor. E.g. "Fixed RTK". It is only available when the crosshair is snapped to the sensor. - IE
  • @position_averaged_count - This variable holds the number of collected positions from which an averaged position was calculated when digitizing in this mode. For non-averaged positions, the value will be set to 0 (zero). - IE
  • @position_fix_status_description - The GPS Fix Status "NoData", "NoFix", "Fix2D" or "Fix3D" as reported by the sensor. It is only available when the crosshair is snapped to the sensor. - E
  • @position_fix_mode - Fix mode (where "M" = Manual, forced to operate in 2D or 3D or "A" = Automatic, 3D/2D) as reported by the sensor. It is only available when the crosshair is snapped to the sensor. - E
Info
Examples:
  • when the crosshair is snapped to the sensor - @gnss_horizontal_accuracy > The horizontal accuracy of the coordinate (in meters) as reported by the sensor. - @position_horizontal_accuracy > The horizontal accuracy of the coordinate (in meters) as reported by the sensor. - @position_source_name --> sensor name.
  • when the crosshair is manually moved - @gnss_horizontal_accuracy > The horizontal accuracy of the coordinate (in meters) as reported by the sensor. - @position_horizontal_accuracy > The value is NULL. - @position_source_name > The value is manual.
Usage
A short press on the GNSS button will turn on the GNSS and center to the current location once positioning information is available.
Activate edit mode and press on the target button, the cross in the center means it is using GNSS positioning.
A long press on the GNSS button will show the positioning menu.
Inside the positioning menu you can turn on the positioning display which will show the current coordinates which are reprojected into the project CRS along with precision information.
If you see WGS 84 lat/lon information instead of information in your project CRS, you probably have no signal yet.
Using an external GNSS-Receiver
QField supports connecting external GNSS antennas via bluetooth.
In Settings > Positioning, paired bluetooth devices can be scanned and chosen as position source.
Make sure no other app like mock location providers are using the bluetooth antenna.
Mock location
It is possible to provide a mock location via a separate android app to QField. There are several options for this, one of them is Android NTRIP Client.
To use this you have to enable mock locations on your Android device.
Back to top
