Attribute form¶
QField creates forms similar to, but not equal to QGIS. The field widgets from QGIS are supported on a best effort basis and optimized for the mobile use.
Widget type | Suporte | Notes |
Text Edit | - HTML is not supported - Numerical input is enforced based on the type. |
Check Box | ||
Value Map | ||
Hidden | ||
Attachment | This field is combined with camera integration. It is also able to open other files like pdf and doc (if you have an appropriate viewer) Attachment (photo settings) | |
Date Time | ||
Range | ||
Relation Reference | ||
Relation Widget | ||
Value Relation | ||
UUID Generator | ||
QML / HTML Widget | ||
Others | Funding |
Editable¶
Remember last values¶
Suppress attribute form¶
The setting suppress attribute form is directly applied to the QField form.
Drag and drop designer forms¶
Configure a Relation Widget¶
The visual identification of the list entries are done via the Display Expression of the child layer.
Key handling¶
Many-To-Many relations¶
Configure Attachment/Pictures Widget¶
It can be used to:
- show and take photos
- show links to external files like pdfs or documents
The option hyperlink on the attachment widget will disable the camera functionality and enable a hyperlink to open a document (pdf, doc, ...).
Configure a Value Relation Widget¶
The widget Value Relation offers values from a related table in a combobox. You can select layer, key column and value column. Several options are available to change the standard behaviors: allow null value, order by value and allow multiple selections. The widget will display a drop-down or multiple-select list of the referenced features.
Configure Conditional Visibility¶
Groups can be hidden based on an expression. This is useful when certain attributes are only required under certain conditions. As an example imagine mapping trees. Some of them might have a disease and you have a list of possible deseases. To not clutter the form with many fields, make a group and configure a visibility expression for a group "diseases". Add a field "desease" with a checkbox. Only when the checkbox is checked, the list of diseases will be available to you.
Let's see what we got on the field:
Define Constraints¶
Attribute fields can have constraints attached. Constraints are
expressions that needs to evaluate to True
(or 1
) in order to be
able to save the form. Constraints are configured on a per-field basis
and a description can be added that will be shown if a
constraint is not satisfied.
Common use cases¶
Define Default Values¶
Fields can have default values configured. Default values are inserted into the attribute form when digitizing a new feature. They are visible and can be modified as long as the field is editable. They can be based on the geometry or expression variables.
Additional variables¶
For more information regarding storing information related to your
position in object attributes, refer to the deticated
GNSS documentation<gnss_variables>
Common use cases¶
Insert the current date and time:
Insert the length of the digitized line:
::: {#snapping_results} If you want to use the snapping results after drawing a line, you can use the [\@snapping_results]{.title-ref} variable. The following code extracts the value of the attribute [id]{.title-ref} of the snapping match of the first point of a line. :::
Configure Auto-complete Value¶
The "Use completer" checkbox must be checked to be able to use the auto-complete in the value relation.
Here a video showing how it works on QField
