Portable project¶
To manually synchronize your QGIS project, you will need a portable
version of your QGIS project file (.qgs, .qgz). Portable means that all paths are relative and datasets are reachable from the device.
Configure a portable project¶
Check that Project > Properties > General > Save paths is set to Relative and that all required data files are in the same folder like the QGIS project file or in a subfolder.
